Instead of having 6 wires running to the rear of the plane, this uses a common red and black wire so there are only 4 wires. It's a bit lighter than 2 standard extensions.
Originally Posted by
hook57
JAS, Thanks much, appreciate the info. I picked pretty much the same as far as accessories go. Will look at the Dubro tail wheel too, I've plenty of planes to use the Sullivan one on. I was going to use a Castle ESC 100 as that's what I have, but could easily try something else. Not familiar with the 1.2M quad extension? Is there an advantage to using it versus the separate 36" extensions? Sure do appreciate the feedback and posts of your assembly as you get time. Again thanks.
Mark
