RCU Forums - View Single Post - Which is a good pull-pull for rudder?
Old 04-29-2002 | 05:18 PM
aftcg's Avatar
aftcg
Default Which is a good pull-pull for rudder?
I've got a 80" Lanier Cap with Brison 3.2.
I need to pull out the rudder servo (Hitec 615mg) out of the tail so I won't have to add weight to the nose. Looks like it would need atleast 8oz in the nose as is. I've read where taking a couple ounces out of the tail is equal to 6 to 8 oz from the nose because the tail is much further from the CG.
I've never used or installed a pull-pull system. Which one should I use?
Thanks for the help.
