Ok got caught up with another project and worked on the H.P. 42 a bit. I see some mistakes I made on the longerons when I built the other half of the fuse on the reverse side of the plans. I added a couple spacers to the bottom inside of the fuse as I added the top formers to give it a little stability when I removed the fuse. The hatch sides were not so self explanatory so I put a couple sticks under to raise them to where I thought they should be. I will probably cut the sides off and adjust when I get the fuse sides done to make the hatch fit better.
