RCU Forums - View Single Post - 12X antenna connection
Old 02-20-2015 | 10:28 AM
Checklst
Originally Posted by Square Nozzle
Checklist is correct. I recently replaced the antenna on my 12X and the antenna connection is a push on connector. No solder.
It makes me a little nervous on my receivers, when I saw that antenna push connector in use, because vibration could be a problem..............now one could drop a radio and think everything is ok and it not be the case. In my receivers I was surprised that they did not think to mold into the case a simple hold down...............when you snap the case together a simple plastic piece built into the case would make gentle contact with the top of the connector.......I even thought about adding a small piece of styfoam cut to the right size would put a little down pressure on the connector when both halves were snapped together......... the epo foam could be glued to the case using hot glue. ( I could just be over thinking it of course)
I however would be nervous if the connector was off metal connectors it will loosen up after a few on off cycles.
Thanks guys for putting that in my mined about my Radio spektrum module .....ignorance was bliss. LOL
