RCU Forums - View Single Post - Internal pressure question
Old 02-20-2015 | 11:25 AM
Thud_Driver's Avatar
Thud_Driver
Ok, so where did all the responses from yesterday go??
People used to "T" off the propane line between the solenoid and engine to use engine pressure to pressurize a smoke tank and avoid using a pump. Said to be around 30 psi or so (thinking P-80/P120). You might measure that if you have a propane start engine.
