Ahhhh common problem....
if u have brakes in reverse but not going forward that means it's setup backwards
so what u need to do....
Reverse channel 2 on the controller, this will correct the brakes, but it will make the car run backwards when it should be going forwards so u need to reverse the direction of the motor, it's done by swapping wires for sensor less motors and a .program card for sensored setups....
providing u do both those steps, u will have normal braking again
