RCU Forums - View Single Post - Inflatable tires???
Old 02-21-2015 | 05:11 AM
abufletcher's Avatar
abufletcher
One more small test. I placed the end of the brass valve with the silicon tubing in place in water. The end with the needle was out of the water. When I pumped air, no bubbles come out so no air is going into the tire. All the air is redirected back out; you can hear it. The problem is that the needle doesn't fit snugly into the brass valve the way a needle would fit into a ball.
