Originally Posted by
acdii
Wonder if you can find 1/4" gas line and use that instead, all you would need then is a fitting.
When I replaced my gas stove, I saved some of the corrugated flexible pipe that looked a lot like the Saito flex pipe. However, the fittings were different (of course) and the pipe, which was stainless steel, was coated with a yellow plastic. I don't have welding equip. or I would have tried to fit some metric Saito fittings. My guess the yellow plastic would just have burned off. But, I have heard that the Saito flex pipes do not make the engines run better, perhaps the opposite.
Sincerely, Richard
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
