Originally Posted by
av8tor1977
I totally agree with this, but would add something. I like to do a few heat cycles on the ground first. Run it and get the needles close to correct. Then continue to run it at varying throttle settings for about two minutes , followed by a blast at full throttle for about 10 or 15 seconds. Then shut it down and let the engine naturally cool all the way down. Do this for several cycles, or one tank of fuel. Now re-tune/finalize your needles, as mentioned, not four stroking rich like a glow engine but set them at a slightly rich two cycle setting. Then fly it!! Don't hover it or Harrier it, but other normal aerobatics, provided you actually use the throttle during them, are good for break in.
Usually after that first tank of fuel you will notice the engine turns over more freely, idles and starts a little better, and holds a needle setting without much change.
I know this is an old thread, but decided to add my "two cents worth" anyway.
AV8TOR
I really think you should follow the instructions that came with the engine.
If they say to runu it on the ground, run it on the ground
If they say fly, fly it.
They have a lot more experience with that particular engine than anyone on this forum.
I had a Brillelly I dont remember that it came with any instructions.
I ran it on the ground for awhile then flew it. It didnt seem to hurt it any
