Intakes installed. They usually will require a little body filler to blend them in nicely.
Before you install them, this inside of the opening needs to be curved with a Dremel drum sander. This is scale. Also in this shot, you can look through the vanes and see the bolts where the big gun speakers will be mounted, pointing right at those vanes.
