Today I started cleaning up the wiring in the Hawk.
I started by removing the forward fuse section from the aft to make it a little more manageable to work on it. I put safety clips on all the connections and also labeled everything so if I need to trouble shoot something It will be a lot easier to deal with. All that is left now is to apply some aluminium tape over the wiring to protect it from heat should the unthinkable happen
I also manufactured a ply doubler for the questionable landing gear bearer and have hysol'd that into place. If I get some time tomorrow I will clean it up, re-drill the new bearing to accept the screws and attach the landing gear to the wing.
The next job is to start to tackle the nose section wiring and plumbing. a big cleanup job is required there as well as to start to plan where the powerbox will go... need to buy that first.
dave
