Truckracers' comments are spot-on. The only engines I routinely break-in on the ground were ABC racing engines. Those I would run at peak for 3 minutes then allow for a complete cool down. Thermal cycling. Ringed engines just need running time. Plus, they run cooler in the air because of airflow and the fact that the prop unloads in the air, but not on the ground.
