Originally Posted by
zippome
Ok Guys and gals , here we go!
1. This aircraft was designed and built due to experiences in the previous war.
2. It was built with extra armor around the cockpit and the engines.
Ok, that's the start!
Thanks!
Zip
Well, the Hs 129 shouldn't be left out, with the Spanish Civil War being the "previous war" to WWII. Thanks; Ernie P.
The
Henschel Hs 129 was a
World War II ground-attack aircraft fielded by the
German Luftwaffe. Its nickname, the
Panzerknacker (tank cracker), is a deliberate pun—in German, it also means
"safe cracker".[SUP][
citation needed][/SUP] In combat service the Hs 129 lacked a sufficient chance to prove itself; the aircraft was produced in relatively small numbers and deployed during a time when the
Luftwaffe was unable to protect them from attack.
Rudolf-Heinz Ruffer scored a large number of his 80 Soviet tank kills in the Hs 129.
By the mid-1930s, the German military, as well as its counterparts in other countries, had come to see the main role of ground attack aircraft as the
interdiction of logistics and
materiel, a task in which targets were often poorly protected, less likely to offer strong, well-coordinated resistance. For high-value, well-protected tactical targets,
dive bombers had become the conventional solution. However, the experience of the German
Kondor Legion, during the
Spanish Civil War (1936–39) turned this idea on its head. Even though it was equipped with types unsuited to the role, such as the
Henschel Hs 123 and
cannon-armed versions of the
Heinkel He 112, the
Kondor Legion proved that ground attack aircraft were a very effective weapon. This led to support within the
Luftwaffe for the creation of an aircraft dedicated to this role, and the
Reichsluftministerium (RLM; "
Reich Air Ministry") requested tenders for a specialized ground attack aircraft.
It was anticipated that the main source of damage to such an aircraft would be
small arms fire from the ground, meaning that the plane had to be well-
armored around its
cockpit and engines. Similar protection was also needed in the
canopy, in the form of 75 mm (2.95 in) thick
armored glass. The aircraft was expected to be attacking in low-level, head-on
strafing runs, so the cockpit had to be located as close as possible to the nose, in order to maximize the visibility of its targets. Another, non-technical requirement, severely hampered the designs: the RLM insisted that the new design be powered by engines that were not being used in other designs, so that the type would not interfere with production of established types deemed essential to the war effort.
Only four companies were asked to submit tenders, three submissions followed and only two of these were considered worthy of consideration: one derived from an existing
Focke-Wulf reconnaissance type, the
Fw 189, and Henschel's all-new Hs 129.
