Originally Posted by
zippome
Not the P-38!
1. This aircraft was designed and built due to experiences in the previous war.
2. It was built with extra armor around the cockpit and the engines.
3. The aircraft was used to inspire the pilots that flew it.
4. It's designer went on to build iconic warbirds , for another manufacturer.
5. Two main variants built.
6. The contracted number of aircraft to be built was cut in half of the original order.
7. It's first flight was from an airfield located in Dayton Ohio that you may have heard of.
Ok, that's the start!
Thanks!
Zip
Okay; I'll take a shot, based upon the first four clues. How about the Boeing GA-1? A five ton armored triplane, intended for ground attacks, it was certainly an... interesting... aircraft. Designed by Isaac Machlin Laddon, who later designed flying boats, for the USAAC. Thanks; Ernie P.
Answer: Boeing GA-1 (Model 10)
The
Boeing GA-1 (company designation
Model 10) was an armored
triplane. Designed in 1919, it was powered by a pair of modified
Liberty engines driving
pusher propellers. The first of the
Engineering Division's heavily armored
GAX series (ground attack, experimental) aircraft, the ponderous airplane was intended to
strafe ground troops while remaining immune to attack from the ground as well as from other enemy aircraft. It was so well armored that its five-ton weight proved excessive.
Soon after the end of World War I, the US Army sought to explore highly armored and armed specialist ground-attack aircraft. This was a pet project of General
William Mitchell. The Army Air Service Engineering Division issued requests for proposals to U.S. aircraft producers on 15 October 1919. There were no designs offered, so the Engineering Division ordered one of its engineers,
Isaac M. Laddon, to attempt what the aviation industry clearly considered impossible. His design, designated GAX, first flew at McCook Field on 26 May 1920. The GAX was McCook Field Project P129 and wore AAS serial number 63272.
Aerodynamic cleanliness was sacrificed to fields of fire for its eight machine guns. The sturdy structure was able to carry a heavy load of ammunition along with about 2,200 lb (998 kg) of armor plate. The result was an angular machine of wire-braced wooden construction with plywood and fabric covering. A rectangular-section fuselage carried the forward gunner in an open nose position, the pilot in a semi-enclosed cockpit with armored shutters for forward vision, and the rear gunner in an open dorsal position. The engines were carried in mid-wing nacelles.
As designed, the armament was comprehensive. The pilot was in control of a 37 mm cannon, four fixed
Lewis guns fired forward and down, and a machine gun fired forward and upward over the wings. A further two Lewis guns fired to the rear and downwards (through a fuselage tunnel) and a single machine gun up and over the wings. A gunner's position was in the nose. The armor covered the front half of the fuselage and the engine housings.
The top wing was of larger span than the lower ones; the middle and top wings carried ailerons. Span decreased from 65 ft 6 in to 58 ft 6 in between the top and lower wings.
On 7 June 1920, Boeing was awarded a contract for 20 production models designated
GA-1. Before the first was delivered in May 1921, the order had been reduced to ten. The production aircraft wore Boeing constructors' numbers 200-209 and AAC serial numbers 64146-64155. Number 64146 was evaluated at McCook as project P187. The follow-on GA-2 was flown at McCook field in December 1921 with orders to construct two more aircraft.
The GA-1 were sent to
Kelly Field, Texas, in early 1923 for service tests with the only US aerial
attack formation, the
3rd Attack Group. These tests showed the aircraft to be unacceptable. They had poor visibility and performance, particularly in rate of climb, maneuverability, and range. The aircraft suffered from noise and vibrations caused by the 3/16-inch (4.75mm)-thick armor. Takeoff runs were very long by the standards of the day. The GA-1s were extremely unpopular with the pilots conducting the evaluation.
As a result, in 1925 the entire country's attack air force (3rd Attack Group that is, as differentiated from the bomber force) consisted of fourteen
Airco DH-4 machines, inadequate even for training, let alone for combat.
It was rumored that the GA-1s survived until surveyed on 14 January 1926, so that Kelly Field pilots could be threatened with being forced to fly them for disciplinary infractions. All were scrapped in April 1926.
Isaac Machlin Laddon (25 December 1894 – 14 January 1976) was an American
aeronautical engineer and designer.
He was born in
Garfield, New Jersey.
