2FAS I just went through this procedure on the DS14. I want to add one thing to what LA Jet Guy stated. The two plugs that you will remove have a two locking tabs that you depress from inside the Tx Case.
Take a very narrow flat bladed device and depress the tabs while pushing out the plug. DON"T simply try to force the plug out!
You can add features as you have the need!
The battery is a 5200 Li-Ion. Not a 3200 Lipoly
