I was curious on the specs, had to look it up again. The fabric is certified for any aircraft with a wing loading under 9lb/sq ft. Should be okay..
Depending which fabric you buy light uncertified grade is 1.7-1.89 oz/sq yd. It's really heavy for small models but I had 10 yards of it so it found it's way on a couple of Demons. Not too many around with tougher covering than those two. Or heavier, but they're not bad as you can see from the numbers. I bought a pack of SIG Koverall and will use that next, it is a fair bit lighter than the uncert grade.
