The engine was purchased directly from Horizon Hobbies. Rather than return it, I guess I'll continue with the break-in (I hate that term) procedure - I suspect there was some surface rust somewhere - I suspect the cam - going to flood the inside with after-run oil and look at what comes out. If it's really disgusting, I'll give HH a call. Thanks for the comment - we need spring here in Pennsylvania, USA., really badly!
Originally Posted by
cymaz
If its shop bought, then let them look at it. You could have the back off yourself...but you know what that meaninvalids hop could argue that the warranty is invalid.
Though not rough, mine was very tight. Took an age to run in, it melted one starter. Now it's a beauty. Always run it out bone dry then put a good amount of after run oil in and span it up to get the oil everywhere inside.
