Originally Posted by
ww2birds
Hi Carsten,
Been playing with the new telemetry setup with a Samsung AMOLED tablet. It is just stunning, everything worked perfectly on the first try. Nice map images .. out of curiosity .. how large is the data set you needed to do that?
You mentioned the new PSENS with I/O .. how is that coming along?
Also, what's the best way to do firmware updates on the ASSIs (and any other devices).
Dave
Hello Dave.
I am sure that Carsten will be delighted to hear your appreciation.
Firmware update is not straightforward. It requires a special programming board and is done via PC to load the micro controller.
At the moment there is no need to upgrade any firmware. As you can see, Carsten releases very stable firmwares without any bug. So the version you have is final.
We only swap firmwares to enable different remote control compatibility.
The new board with I/O is called ADSB. Analog/ Digital Serial Board. It is not meant at replacing the SB-PSENS but complementing it with different functionality.
One of the two main features of the ADSB is that it is able to work as a gear failsafe with its pressure sensor and that it has I/O PWM.
