SJhanc, so let me try and summarize:
The motor: RIMFIRE 65cc.
Battery: 12s 1p (2-6 cell packs in series) GensAce 5300mah 45c.
ESC: Castle 160HVF.
Gross weight: 28.5 pounds.
Prop: Ramoser VarioProp 22.6
Static Test #1: @ 14 pitch
Watts: Peak 4510
Amps: Peak 119.3
RPM: 4861
Flight Speed:
TBD
Mtr Temp:
TBD
Flight Time:
TBD
Static Test #2: @ 16 pitch
Watts: Peak 3525
Amps: Peak 87.8
RPM: 4200
Flight Speed:
TBD
Mtr Temp:
TBD
Flight Time:
TBD
When do you think you will be able to use the Zinger 4 blade prop? BTW I didn't really understand the problem you had mounting the Zinger 4 blade to the R65 motor. Is the prop hub to thick for the shaft / thread length? Do you have any pics?
Thanx, Mark
