Hi Guys,
I am finally getting my tx/rx setup for real..I need some help.
I had set up my two receivers with Cbox200 for my A10 and had that set for that plane in dual path mode. I made a new model for my F16 and am using the same receiver/Cbox. Will the transmitter continue to use this now as dual path or do I need to figure it out again how to tell it the same for this F16?
I also can't get my lights to stop flashing…(BVM F16 PNP despite two full travel assignments.
Finally how do I do a mix for rudder to nose gear that is active only when the gear is down? I did this all of the time in my 10x but am not sure where to do it here.
I know these are kind of basic questions but thanks for your help.
Dave
