Originally Posted by
ww2birds
Thanks for the pointer on the device from Gaspar. So in order to use the Xicoy ECU, this is the only way, right? You have to have one of these devices? No direct connect like the JetCat?
Dave
The Xicoy ECUs use their own serial protocol. The Xicoy conversion board translate this protocol into a Jetcat serial protocol that can then be fed into the ASSI unit.
