Originally Posted by
gunradd
Well just got back from Flroida jets and here is my user report. I was using the eagle tree and it did ok but not great. So got the new 3E. After 8 flights of fighting with it and trying to program it after each flight and it still acting very bad in the air I pulled it out. The cortex dealer was nice enough to trade me a cortex to try out and from the first flight it was good to go and completely love it!
So not sure if I just had a defective unit or something but I was better off with no gyro or the eagle tree gyro over the 3E.
Sorry you didn't had a good luck with the iGyro 3e like all the rest.
If your mechanical set up was right enough for the cortex to work then you should have no problem with the iGyro 3e.
So your problem maybe was : -loose installation -or wrong gyro direction installation -or wrong gain programming.
PowerBox is currently the only RC electronics manufacturer, which is officially licensed and regulated under DIN ISO 9001:2008 industrial norm.
Meaning you have less chances to get something defective from them than with anyone else.
But if you do they will stand up for you.I had only but great service from them.
Next time you have the chance to try the iGyro 3e give it a go.The deference over the cortex in the smoothness and the natural feeling is very noticeable !
