RCU Forums - View Single Post - PowerBox iGyro 3E > user report
Old 03-08-2015 | 06:38 AM
gunradd's Avatar
gunradd
My Feedback: (9)
George it was installed correctly Ali himself even helped some. This also is not my first gyro install..... I had to buy the programming cable because the thing was so bad I was hopping that would correct it. But it didn't and just made things worse. I couldn't go over 11% gain with out the aircraft porpoising. Cortex was fine from the first flight and the same with the eagle tree. Like I said I must have had a bad unit the way it was acting.
Also 50% of the time I had to recycle power to get my flight controls to even work on start up. And yes I followed the directions not to move them until the gyro boots up with transmitter on first...
