Some pics of the steel parts after an overnight soak in Evaporust. I used some Bar Keepers Friend to clean up the cambox in the crankcase. Not a lot better than before. I think I'll let her ride and run it. I need to get the liner out and clean up a little surface corrosion in the bore but otherwise it's probably as clean as its gonna get without an acid dip or sandblasting.
