Originally Posted by
Ram Jet
Hi Quickie,
That little tiny bearing that supports the camshaft at the very back of the engine. Here's how I got it out. I heated the aluminum housing on my gas stove and then wacked the housing soundly several times on my counter top. The bearing fell out.
Just a thought,
Bill
I baked all of it and a little whack on a block of wood got all of the bearings out including the tiny cam drive bearing in the cambox cover. It was the easiest to get out even. Heat is our friend with these things. I got the liner out too.
edit: if this engine had a lot of time on it, I could see the cambox bearing being a real PITA to get out. I had a candle and wooden dowel on hand in case I needed to use that trick to get that bearing out.
