My day at cursing at my Jeti
This has been discussed before but:
The new menu for aileron differential works well to reduce down travel of the aileron if you modify the down deflection value on the ground.
Problem starts when you want to do the adjustments while flying. If you assign a knob to the function and a % adjustment it adjusts both aileron not just the down moving aileron.
It has been suggested to reduce the max travel limit to stop the upward moving aileron from going any further. That works well at full deflection,
BUT with any lesser deflection you get the upward moving aileron being still affected by the knob
Any suggestion?
EDIT: Never mind ZB answered me that this will be fixed in a future update
