Originally Posted by
izzy
We'll I made a set of new mounts and angled the turbine even more down thrust and that did not help much
yesterday I added 2 washers under the front bolts that hold the elevator to the booms changing the elevator incidence and that made a huge difference
Can it be I received a dud kit with the incidence between wing and elevator way off ??
if anyone else had this would appreciate your feedback
izzy
I have had the servo lead trapped under tail plane a couple of times which makes the trim out a little, I made the cut out in bottom of tail plane bigger to allow it to sit flat, it's only a small amount so not easy to see that it's out till you take off.
