Sounds good Dave, I found info in the manual to work with and put together a list of servos I will need for it. With your input, I feel confident that my choice is good. I have picked out these Hitec Servos for use;
HS-5645MG approx. 170oz/in(12.2kg/cm)@6V- 4 total for Ailerons, Elevator, and Flap(Digital Metal Gear)
HS-5245MG approx. 76oz/in(5.5kg/cm)@6V- 2 total for Rudder Pair(Digital Mini Metal Gear)
HS-645MG approx. 133oz/in(9.5kg/cm)@6V- 1 total for nose wheel steering (Analog Metal Gear)
HS-81 approx. 42oz/in(3.0kg/cm)@6V- 2 total for air valve actuation for brakes and retracts. (Standard Mini)
