Originally Posted by
Hossfly
Maybe I have posted this times before, but here is a real trick for a couple engines.
1. Fox .29,.35,.40 engines for CL. Remove the Fox needle valve assembly, and replace with either of an OS CL NV or an Enya, same. Be sure that the rear hole in the NV is JUST out of sight facing rear. OS and Enya are about same, with ONE (1) hole. That hole should be facing BACK and JUST out of sight.
Interesting. I found an Enya NVA on E-Bay, think I'll give that a shot.
On the FOX NV, if you must use it, be sure for stunt flying the rear hole is same as above, just out of sight. The front hole will then be facing front and create some very good (or not good
) BURPS in most aerobatic maneuvers. [...] You may need some small washers to center the NV in the hole. Use 'em!
Think previous owner of the engine may have been having some problems with that engine as you describe. I'll look into the Enya NVA.
For all those old Testor's McCoy red and blue head engines, they were good but short-lived. One secrete that worked well if one really knew how to do it was:
After some good flying time and they got rather difficult to finger start do this" Prop size 9" diameter, 5-6" pitch. Use a rat-race setting with 10-15% oil fuel, and needle it to maximum. Take off an be ready to NOT get too much round and round until you know it is really leaning out. Let it go as fast as it will. (might have to do some inverted but best if then "RAT-RACE" speed is maintained.) When it stops it will be smoking a bit if everything worked.
You will find that the heat swelled and hardened the piston. Once it cools down, the engine will be very quick to start, runs better than you will have ever known, and will last a long time. This came to me about speed engines from a great speed CL flier. SWELL THE PISTON! NO,
NOT for ringed engines, just lapped pistons!!!
It works!
Interesting. Some have been mentioning about heating outside the engine when worn, to swell to fit. I've never heard of your method, some food for thought.
Any of you guys ever fly the Grey McCoys built around 1971-73 era. Very powerful, but came out at the wrong time, built by Testors up near Rockford, IL. They were good RC engines, but the rings were not tight and difficult to start, especially by flipping. As a rather good CL Stunt Man that owned a Hobby shop back then, Testors pushed on me to fly a pre-production one at the NATs in Glenview. I removed my fantastic George Aldrich rebuilt Super Tigre. 40 and replaced that with one of these new "McCoy Testors". I got in one good test flight the day before and one early before my first flight at Glenview. That first morning flight was a good flight, in the top 5. The 2nd official was going great, and I was drawing a crowd around the fence. Then came the UN-GREAT! For some reason the engine flamed into Rat-Race lean and I was over-time by at least 2 minutes, negating my 4-leaf clover, the landing, and pattern-points. I tried every maneuver I knew to shut-'er down, but was out of the placing, no chance for the top-ten.
Needless to say I did not give a good review of that engine. OK for RC but not for CL Stunt. If you have one, you might like it. I flew one, a 35, in a RC Trainer and it was OK by all standards. They never lasted long in the front-lines. I'm sure there is some out in the world, but I do not have one. I think it was actually made by K&B, had all the parts but I have no recall of what Testor's finally did with the design. Ain't RC History GREAT?
Do you mean the Testors Series 21 Black Head engines? Sorry to hear of your CL loss. Would have been better if they had given you the engine [at least a few weeks before] to try out prior to the contest. Then you could have had a chance to "debug" it or give it back to them with what issues you encountered.
