Hi All.......don't want to "highjack" this thread,but thought the below may be of help............?
These are the photo's of my 7-77 set up...............with regard to the "lack of thread" issue...?
After I did the CDi conversion,with some extra maching on the split collet and prop-driver and back plate,these are my own approx figures.............may help..?
Crankshaft / thread available length from face of prop-driver...................46mm
Biela hub thickness......................................... ..........................................27mm
Machined backplate......................................... .........................................8mm
Thread available for "NUT".................................................. ......................11mm ( distance from face of sensor ring to prop-driver face is 15mm,allowing a 1mm air gap )
( Solo hub that I have is 49mm thick,but no problem,as it comes with a special nut,which you custom cut to fit your set up ).............when I decide to make use of it !!!
These are only my own thoughts on the "jam-nut" issue,7-77 as stock does not have a jam-nut fitted,just a split wire ring at the end of the thread crankshaft,together with a "normal nut"
I was dealing with TT on the supply of a hub set up and after some information received,I ordered a TT-0125-A ( 10x1.25 ADP kit ),this IMHO is more than adequate for the job and when well torqued tight............no problem and has not been any issues.
Kind regards...............Nick (UK).
