RCU Forums - View Single Post - Fuel Blend
Thread: Fuel Blend
Old 03-16-2015 | 02:14 PM
fiery
Fuel composition sounds fine.
Correct setting for any modern (non fixed compression) diesel requires adjustment of fuel-air mix (needle valve) and compression. Without checking your needle setting you will never an achieve the optimum.
Once adjustments are correct a KMD 2.5 in sound condition will run very well indeed. You did not specify a propeller. I suggest an 8 x 4.
