RCU Forums - View Single Post - M4a1
Thread: M4a1
Old 03-17-2015 | 09:44 PM
  #32
RichJohnson's Avatar
RichJohnson
Ive been hard at work. Lots of things done.
Stowage board installed across the transmission cover. The board comes off, it is just sitting in place right now.
Hull lift rings installed and "welded" in place.
Filler plates installed behind the gun mantle to cover the gaping holes top and bottom. What a pain in the butt that was. I still need to putty around the panels to blend them in. Next time I am going to try from the beginning to use Nick's turret mantle mount casting.
I also made some molds and castings of body clips and got one side installed tonight. Works well. Hull should fit tight, might wind up being too tight.
ID:	2082223   Click image for larger version
ID:	2082224   Click image for larger version
ID:	2082225   Click image for larger version
ID:	2082226   Click image for larger version
ID:	2082227   Click image for larger version
