Thanks @mjhheli !
Looks like good temp readings, but it seems like they are very low? Do You make the measurements on the top or on the cylinder area where combustions is taking place. They are normally warmest there.
I`ve started mine today after the winter and even if it was run empty and got oil inside it was a bit sticky and some small particles in the carb I had to do a full cleanup and also valve adjustments. New start and test tomorrow.
If I´m going for Saito FG 84 carb do I need more than carb? Any inlet suitable?
