Originally Posted by
jymz
I got a couple ECHO PB-2400 engines off ebay the other day to convert for a twin. Is it possible to have one counter rotating? With this conversion I was planning to try the OS gas glow plug so ignition shouldn't be a problem.
http://www3.towerhobbies.com/cgi-bin...?&I=LXEJRG&P=Z.
With piston porting or reed valve induction, the engine should run either direction (remember the Cox reed valve engines?) depending on the ignition timing (either magneto or CDI) that will determine the running direction. If using the OS plug, it should run either way. The induction timing on a disc or crankshaft valved engine like most glow engines determines their direction of running, although some engines with a bolt on front cover can be reversed by rotating the front cover 90 degrees. Good luck with the OS plug. Report back here how it works for you.
Sincerely, Richard
Club Saito #635; Saito 56, 100, 120abc, 130T, 180; YS F 120;
Super Champion 61; Rhino 100; Cameron 19; Fox 35, K&B 29, 35, 40, 65;
Como .91; ASP .91, 1.08; Kraft 61; OS 15, 25, 40, 46, 60, 61, 80; HB 15, 25, 61;
Royal 25; Evolution 36, 46, 61; Echo 16cc glow; Echo 22 cc Ign.
Zenoah G23 ECDI, Ryobi 31, Ryobi four stroke, O&R Industrial 1 hp,
Allpina A330, Various Poulan, Weedeater, and Homelite, etc, etc.
