Originally Posted by
kalzone
hi Todd D,
i am the one one who put the actuator in my corsair and made the drawings for my fellow corsair builders. when i chose the spot i did i didn't need to use the air as i was using the robart electric gear and that was the only spot i could get both hands to be able to work on the setup. the area behind the wing is very hard to access unless you have very small and flexible hands- arms. i have an electric motor so no need for a fuel tank. since i made the drawings i have changed to the sierra air gear as i was having problems with the robart setup i used two of the small air tanks where the fuel tank would go. i know one of the small tanks is not enough volume for the gear but you might be able to put two small ones in. one under the bar that the canopy is attached too and the other on one side of the fuel tank or the two towards the wing but below the pushrod tubes.
Can you share the drawings here or point to the posts that you already made?
