Originally Posted by
Carosel43
Even at its current age we still have spares for it as they are mostly the same as the current spec engine. The only problem is the head bolts. I do not expect it to need anything though, and it should be ample power for the Ercoupe. I would suggest an 18x8 prop to start off with and a 20x6 if the 18x8 makes the model too fast. You should expect about 7500-8000rpm on the 18x8 (depending on fuel/brand etc) and idling rpm below 2000. On board glow is not required and if a cylinder drops out its just letting you know its tuned incorrectly and wants a tweak!
That sounds good there are still parts and just the head bolts are different. The 200V should be more than enough for the Ercoupe as it calls for a 26cc gas. I originally wanted it for a GTM D8 for it but settled on the Ercoupe for now. Maybe someday after I am tired of the Ercoupe I will go for the D8.
Here are the specs for the Ziroli Ercoupe.
Scale: 2.66" - 1'
Wingspan: 80"
Length: 53"
Wing Area: 900 sq/in
Weight: 26lbs
Power: 26cc gas
