RCU Forums - View Single Post - Ram 500R Parameters
Old 03-20-2015 | 07:39 AM
sidgates
Originally Posted by Kevin Greene
Can anyone with Ram 500 experience give me the start parameters that work best for you??? My ECU is an old version (B01M)...I know that the latest version of the Ram 500 ECU is the best but I don't want to invest in a new ECU as I don't know if this turbine is viable yet...I just want to get this turbine started and running before I invest in a new ECU...
THANKS!!! Kevin
Kevin - You didn't say what gas you are trying to use. When I used Powermax I had a lot of trouble with starts using the orginal thick walled bullet shaped gas container. I had better successs when I changed to a much larger white cased container. Don't know who made it, possibly Jetcat.
I upgraded to CO3 and also switched to Coleman Green Propane using a valve I bought from a company in Canada. With this setup I open the valve one click just as the starter spins up and after it lights (pop) I open 1-2 more clicks to insure acceleration. I have also switched to a 2 cell lipo instead of nicad, this holds constant voltage much better and starts are more consistant with the lipo.
