If lipos are so dangerous, why do people use them? Is there any advantage?
Btw, let's say I buy a 5000mah nimh. Since I have the built-in charging socket, I need the special plug on the charger's wire... or should I just buy a charger with tamiya plug and remove the upper hull every time I charge it? It's very quick too.
How does a 5000mah nimh would last? My tank is almost full metal, so its heavy, but it doesn't have a smoke unit and I don't do IR battle.
