Originally Posted by
Joe Westrich
Hopefully the Rx dual battery telemetry is more accurate on this unit. I am always getting falsely low batteries reading whenever running it through a battery back up system.... It is always 2 tenths low. Also Futaba....if you are listening.... can you take the voltage reading out to the hundredths. 6.6 doesn't tell me if it is 6.61 or 6.69 which is a huge difference in residual capacity for an A123 battery. Thanks!
While reading voltage to at least 2 decimal places makes sense, if they have telemetry in the unit I would hope they would track the current and capacity used for each receiver pack as well. Knowing how much capacity has been used from each pack would be far more useful then the battery voltage for an A123, no matter what the resolution.
