Originally Posted by
Oldcrow p51
Mine is built up but the engine is remaining. I'm using DA60cc and Dave Brown spinner. I have problem with the wing joint it's very tight and not fiting flash. I don't know if any one had same issue. The plane is huge comparing to TF stang or any other brand. Can't wait to fly it. I hope any one has flying video of this beautiful bird.
My wing tips were very tight and I had to dremel out one of the holes (left front) where the tab goes thru in the main section since they glued it at a down angle in the factory. Better tight then loose. I would just work it with your tool of choice to get it to go together. If it is real bad you could call HH and have them address it but I doubt that is worth it and another set will probably be worse since it did not move thru the factory with your fuse and main wing. If the main is not fitting the fuse well you'll need to address in a similar manner. One of the guys in the thread had some good pointers if you look back.
