I do not have the onboard starter (didn't think it would fit in the cowl); however it doesn't need it. It always pops in less than 10 flips and is running in 2-3 more. It was a bear trying to find a wrap-around muffler that would clear the firewall. Finally settled on the j'tec compact wraparound. Fits almost perfectly inside the cowl as well. I had to cut a little at the front corner and to clear the front muffler bolt.
here are some pics:[
QUOTE=marksp;12007401]Do you also have the EME on-board starter? Can you share pics of the engine installation and cowl mods if any?
Cheers[/QUOTE]
