Originally Posted by
mr_matt
Rob Janiger showed me a trick, you loop the cable through one side of the nose strut tiller arm over to the other side and then back to the servo. The crimp connections are only on the servo side, the rest on the nose gear side is just a loop.
Matt,
I like the idea of simplifying the connections at the nose gear. How do you keep the cable from sliding through the holes on the tiller arm?
Craig
