RCU Forums - View Single Post - Need some Advice here
Old 10-14-2003 | 07:12 AM
DBCherry
Default RE: Need some Advice here
Spooner,
Point well taken! Once again, failing to ook at location takes a bite outta' my butt.
Trials,
Glow is generally less expensive. Gas engines are considerably larger (size and displacement), and therefore require a much larger plane, larger servos, etc. I would guess a minimum of $700 to $800 to get started with gasoline.
Good luck with whatever you decide.
Dennis-
