Originally Posted by
DaveyMo
Greetings Again:
I just returned from a bench run if the KMD 2.5 taking all of the above into consideration (no, Mr. Cat123). My preliminary conclusion: methinks somebody goofed up on the fuel mix, and I shan't say who that might be!
Running it last fall on the 8x4 prop and commercial fuel, I easily got 12,000 RPM. Today with the same prop, the same contra and needle settings, I got a sputtering 6,500 tops. Maybe I should bite the bullet for the commercial fuel and use my own mix for wood-stove fire starter? Or, should I try goosing my mix with more ether or Amsoil?
Either way, this KMD is a lovely little engine and I'm willing to figure things out to keep it happy! Thanks.
Dave Mo...
Hi Davey, at this point, I have to say; bite the bullet and get commercial model diesel fuel. Your KMD should turn an 8" X 4"
close to 14K.
Tony
