Got the hull washed up tonight for painting prep.
Also I decided to move the switches up into the hull and seal up the holes on the bottom as well as the holes on the side with the ABC switch hole left from the old RX14 system that HL never eliminated from the molds. I guess its hard to tell in the second picture, but I mounted the on off switch on a piece of plexi up above and behind the drivers hatch so that I can open the hatch and turn the tank on and off and if I want, adjust the volume because I just flipped the control pot over and screwed it back down.
I am debating whether or not I want to cut the battery box open and glue the bottom on and seal it up and just go through the top every time since I installed the body clips, it would be really easy to do it. Not sure yet.
That's it for now. Tomorrow comes the paint job. Working on decals still, Ksoc and I should have a proof sheet soon.
I have decided to name this tank California Girl.
