Originally Posted by
sparky4lawndart
Make sure it isn't RF generated by a bad spark plug... I have to replace my plugs every 50 flights due to weird servo chatter that begins to occur...
Thanks, I will, but fairly certain it was the servo. The throttle and choke were the only servos that I re-used from my Weeks when it got updated, and while it had an issue with one, I was fairly certain that i had it narrowed down to the extension being the issue, not the servo. Guess that was incorrect, but thats the reason that only those two controls got used servos On them. Anyway, replaced it and cut the lead this time. I've since ran it for about 10-15 minutes and the issue is gone. Should be good to go.
