I am using the hard plywood as the bushing and the hinge line is on the rudder side.If I find the ply wood is getting wear I could always slide a brass tube over it but doubt it will be needed. I used a grinding wheel to cut a slot in the rudder then used hysol to secure the pocket inside the rudder.
