RCU Forums - View Single Post - old timers look here must be 50+ years only
Old 03-27-2015 | 04:45 AM
  #1296
buzzard bait
Well the other guy has flown one, so you can't go wrong there. I mix some rudder with aileron on my WWI types because the ailerons don't have a pure roll axis effect anyway, they also induce adverse yaw. So I figure I might as well take some of it out with coupled rudder. But I don't rely on right stick only, I use the rudder stick too.
Where I differ with his is "you'll kill it" if you mix in rudder. Did he actually try that? How much? That part sounds highly dubious to me. But suit yourself. It's true that if you use plenty of rudder on the turns you won't need coupling.
Jim
