RCU Forums - View Single Post - Cor-Star 60 Version 2.0 plans and pics
Old 10-14-2003 | 10:36 AM
Deadeye's Avatar
Deadeye
Default RE: Cor-Star 60 Version 2.0 plans and pics
You should now have a spar built, assuming you can understand my instruction and drawings.
Next step, the wing panels. I always run my flutes chord-wise. The pic shows the majority of the dimensions. The strip at the tip of the 11 3/8 measure is about ½ inch wide. One side of the plastic was removed for the leading edge. Total width of the panel is 22 ¾. So you need 2 panels 35 ¾ X 22 ¾ . The 22 ¾ should run with the flutes.
ID:	67649   Click image for larger version
