to use your aileron servo for the flaps, all you have to do it make a "y" pushrod, this is just two rods soldered together, nothing fancy wrapped with wire soldered with plumbing solder(lead stuff if you have) or electonics type solder. I can post a pic later when I get home from work if you like.
